GPU or PSU problem?
By
jayzackzz
in Power Supplies
in Power Supplies
Solved by jayzackzz,
Problem solved, the problem is in my motherboard pcie settings. Forced pcie gen 3.0 in the BIOS instead of putting it on auto. Not sure why there is a pcie gen 4 option since my H470 motherboard shouldnt be supported, must be causing some conflict or whatever I'm not sure. No crashes after few hours of 3dmark stress test.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
