Budget (including currency): Taka
Country: Bangladeah
Games, programs or workloads that it will be used for: workloads
Other details: "Boost my Build" please........
PCPartPicker Part List: https://pcpartpicker.com/list/TBFG9N
I just want an 8 core cpu,and the pc should be airflowing because the place i live in is too hot.
And I cant increase my budget more than this.
https://linustechtips.com/topic/1362964-boost-my-build/
There isn't that much of a difference between a 75hz and 60hz monitor (to my eye) so you'd might want to downgrade it just to a 60hz.
With the money saved by changing monitors, i suggest a 600-650w PSU.
There is always 2nd hand GPU's on places like FBMP where you may get a better deal.
https://linustechtips.com/topic/1362964-boost-my-build/#findComment-14917174
