Hi, I need advice for buying a good hub switch unmanaged that have 16 ports and that is 10/100/1000 and with a good warranty. I need to put it in a suspended ceiling but no problem for the space and i can make a rack so it would have a good ventilation.
Do I need to buy cat 5 or cat 6 ... shielded or not shielded .. it's for a house. I will link tv receivers & computers. I'm from Canada so I need a good support if it's lifetime warranty.
Sorry if my english is bad my first language is french.
Thank You.
https://linustechtips.com/topic/1362631-hub-switchs-unmanaged/
Be careful with terminology here. Hubs and switches are two different devices. Hubs are pretty much entirely obsolete and there's no reason I can think of to buy one over a switch.
For what you need, pretty much any unmanaged 16 port switch from a known brand like Netgear, TPLink or DLink is fine. Cat5e and up is fine for cabling and in most cases you won't need shielded cables either.
https://linustechtips.com/topic/1362631-hub-switchs-unmanaged/#findComment-14914869
7 hours ago, MystiqueAngel said:
Thank You for the reply, an other question without making a new post : What connection should i make T-568A or T-568B ?
Thank You again ^_^
B, always 😄
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1362631-hub-switchs-unmanaged/#findComment-14917381
