aight so it started today, i just wanted to play valorant and i get 30-70 fps instead 130 - 200.. cpu and gpu clock are normal , usage and temps too. well not too normal since i have a laptop but it is as always.
same with genshin, i get like 30 fps suddenly instead 60. now stupid me did download something pirated today , but i deleted it and scanned my pc with malwarebytes ( a short scan) and nothing was found. i have restarted my pc 3 times and still the same. please help
btw i only see that now but for some reason windows explorer is taking half my cpu usage.. and %80 gpu usage
https://linustechtips.com/topic/1361392-weird-sudden-fps/
Windows Explorer doesn't like pirated things. Just leave your laptop open and turned on for a few hours and it'll sort itself out. Beyond that we're not allowed to help with piracy but I don't know if that extends to problems caused by piracy.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1361392-weird-sudden-fps/#findComment-14905465
i have a laptop
 stupid question, but are you plugged in the wall?
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1361392-weird-sudden-fps/#findComment-14905469
im not asking for help about the software, i have deleted it..
https://linustechtips.com/topic/1361392-weird-sudden-fps/#findComment-14905501
Yes, but I don't know if it's against the forum rules to help with problems caused by piracy even if the software doesn't exist anymore. But I'm going to assume it's not against the rules so, basically what is happening is Windows Explorer is trying to 'figure out' what is happening with the malware that was in that file, it may have affected other files so it is scanning for that. Open Task Manager, it's probably using maybe 5-10% of your SSD too. Again if you just leave the computer running for a while it will sort itself out.
Works Cited
https://linustechtips.com/topic/1361392-weird-sudden-fps/#findComment-14905507
