first time switching pc cases need help
46 minutes ago, Middcore said:Bad airflow - unless you remove the external magnetic dust filters, which you may as well do anyway because they're flimsy as shit, but even then it's not great and now you have no dust filtering for your system at all.
The re-positionable front/side I/O panel is super flexy when you plug stuff into it, I would be concerned about the ports failing.
The modular feet/handles have to be bought separately and are kind of overpriced for what they are (five bucks for one).
Space behind the mobo for cable management is adequate but there's nowhere to hide cables in the part of the case you can actually see when even many cheap cases now have a PSU shroud.
The acrylic side window, like all of its kind, is super susceptible to to scratches and scuffs and will quickly look awful. Cooler Master announced an "improved" version of this case with tempered glass and then never actually made it.
The stock feet of the case are very short so the amount of clearance under the case for the PSU to breathe is borderline inadequate, so you need to either mount the PSU fan-up (which is not ideal), mod the feet, or buy the overpriced handle-feet.
Basically Cooler Master's tried to make a big splash with the Q500L, which has the exact same dimensions but the gimmick was you could fit a full size ATX board and PSU in a very small Micro-ATX chassis, and the Q500L is a disaster. The Q300L version which is actually designed somewhat sensibly to hold a Micro-ATX system was sort of an afterthought, and it isn't outright "unusable" like the Q500L is but it really has nothing to recommend it besides the fact it is quite compact.
well i decided to go for the Lian Li Lancool 205M since due to the fact that it has a PSU shroud and better airflow and more hard drive space. thanks for the advice and opinions very much appreciated!
