Budget (including currency): £800
Country: UK
Games, programs or workloads that it will be used for: Heavily modded Minecraft, Rocket League, Dead by Daylight is about it really
No extra peripherals needed. My first build!
https://linustechtips.com/topic/1359988-first-build-help/
You're choosing to build a pc at a time where the prices are very high, due to low stocks of parts (covid related) and inflated video card prices due to mining.
800 pounds is a bit low and will result in compromises.
Here's a build that's decent and costs less than 500 pounds, leaving you with 300+ pounds to buy a decent video card on the used market ( buy a RX570 , RX580,  1060,  2060 etc).
It's stupid to buy a new RX 580 at 450 pounds when it was selling used a year ago for less than 200 pounds.
https://uk.pcpartpicker.com/list/sCfxwz
PCPartPicker Part List: https://uk.pcpartpicker.com/list/sCfxwz
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£172.99 @ Box Limited)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  (£74.98 @ Amazon UK)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  (£71.98 @ Amazon UK)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  (£51.97 @ Amazon UK)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (£42.96 @ Laptops Direct)
Power Supply: EVGA BQ 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£55.47 @ Amazon UK)
Total: £470.35
The B550 chipset boards only work with 4xxx and 5xxx processors with integrated graphics.
An alternative would be to get a B450 chipset based motherboard and a 3200g  and use the integrated graphics, but you'll make it harder to upgrade in the future.
Another alternative would be to go for an intel cpu with integrated graphics
Here's a build with Intel cpu  ... it's a bit more expensive because also upgraded ssd and it requires separate cpu cooler (amd comes with good stock cooler)
https://uk.pcpartpicker.com/list/2MJp68
PCPartPicker Part List: https://uk.pcpartpicker.com/list/2MJp68
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  (£187.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  (£32.99 @ Amazon UK)
Motherboard: Gigabyte B560M AORUS ELITE Micro ATX LGA1200 Motherboard  (£114.88 @ More Computers)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£69.98 @ Amazon UK)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  (£83.99 @ Amazon UK)
Case: Fractal Design Focus G ATX Mid Tower Case  (£36.49 @ Amazon UK)
Total: £581.79
https://linustechtips.com/topic/1359988-first-build-help/#findComment-14895782
It's ridiculous, a 2060 in oct/nov last year was 300 pounds, now its 430-500.
   Ryzen 5 5600X (@4.8Ghz) |  ASUS RTX 2060 OC (+120 Core, +1125 Memory) |  Ballistix 16GB
ASROCK B450M PRO4  WD Blue SN 550 1TB ‎‎‎‎‎‏‏‎| Crucial MX500 500GB | Barracuda 1TB
 Corsair CX450M | Corsair Spec-Delta
https://linustechtips.com/topic/1359988-first-build-help/#findComment-14895801
CPU: Intel Core i5-10400 2.9 GHz 6-Core Processor  (£156.00 @ CCL Computers)
Motherboard: MSI MAG B460M BAZOOKA Micro ATX LGA1200 Motherboard  (£88.95 @ AWD-IT)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  (£44.78 @ SmartTeck.co.uk)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (£42.99 @ Amazon UK)
Case: Corsair 275R Airflow ATX Mid Tower Case  (£39.25 @ Amazon UK)
Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply  (£75.98 @ Currys PC World Business)
Total: £519.93
Generated by PCPartPicker 2021-07-27 11:23 BST+0100
You'll need to use the iGPU for the time being and wait for stock to arrive.
https://linustechtips.com/topic/1359988-first-build-help/#findComment-14895837
Would this be capable of running modded Minecraft do you think? I could do with just that until I can get a proper GPU at some point. Doesn't have to be absolutely maxed settings or anything, just playable.
https://linustechtips.com/topic/1359988-first-build-help/#findComment-14895847
You should be able to play it at lower settings with the iGPU, but i don't know how much you'll be modding it.
https://linustechtips.com/topic/1359988-first-build-help/#findComment-14895904
https://uk.pcpartpicker.com/list/mKpDYg
Maybe something like this?
Youll have to use the igpu for now
To make it more tolerable
Overclock the igpu via bios or xtu and overclock the ram
K cpu cause it was only 5£ more and even if you dont oc it, itll have a better resale value than the non k variants
https://linustechtips.com/topic/1359988-first-build-help/#findComment-14895964
