Hi,
I recently got new AMD platform, 5600x with Aorus Elite X570, the CPU is watercooled and temps never exceeds 63 on gaming, however, I noticed the VR Loop which should represent VRM temps as I read are high with 80c Max during gameplay.
Also, regarding DRAM temps are they ok with 70c Max.
RAMs are 4 x 8GB 3200mhz 16-18-18-36 OCed to 3466mhz 16-19-19-32. 1.4v DRAM voltage and 1.148v SoC voltage.
the CPU is on PBO advanced - Motherboard limit - Negative 25 Curve - Auto Scalar - +200mhz overdrive.
I noticed that voltage hit 1.4v on regular CPU for the CPU which is higher for my taste compared to my previous Intel builds but I read its normal for Ryzen.
Not sure if 80c on VRM for Ryzen is normal or not as its surely not for Intel? any advice on how to limit the voltage spikes or should I use manual OC?
https://linustechtips.com/topic/1359253-high-vr-loop-and-dram-temps/
It's normal. All of it. Be it on Ryzen or Intel.
I had 9700K OCed to 5.2ghz at 1.35v tue VRM never reached 65c on Asus rog Z390F, thats why seeing 80c seems to high for my taste. But if its fine then i dont mind
VRM can handle up to 100˚C. But above 90˚C it start becoming problematic. 80˚C there's no issues.
It also depends on your cooling method and airflow in the case. If you had an air cooler before and now you use an AIO and no fan close by to push air onto the VRM, that won't be helping with the temperatures. Same if you had a side fan and now you just have a useless window to see inside the case for whatever reason you might have.
