Dac/amp or audio interface? Recommendations?
Hey all,
I am looking to get a desktop dac amp combo to both power my powered monitors and headphones. There are man dac/amp combos with all the outputs. The issue is finding one that has a toggle for the outputs within my price range that is good.
I am ideally looking around £100-150. I was originally looking at the if zen dac. But I don't want to deal with constant unplugging of cables to select my outputs.
Does anyone have any recommendations for me? Would an audio interface be a good alternative due to output select and seperate volume control?
On a side note: I eq my headphones currently, but If I have both speakers and headphones coming out of the same dac. What is the best way to eq headphones without it effecting the speakers. Or do I just have to toggle the preset/profile?
Thanks
https://linustechtips.com/topic/1358192-dacamp-or-audio-interface-recommendations/
You have powered monitor, right? So, does the pair of monitor have a power on button, can't you switch it off when you're using the cans? IIRC, back when I was using my Rokit 5 3G, I simply didn't power it up when I was using my cans, I was, still am, using an iFi Micro iDSD BL. I've sold off the Rokit5 and have been using an LG soundbar via HDMI from my GPU.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
5 hours ago, rice guru said:
What headphones are you running?
I am currently running Superlux 681 Evo's (but they are weirdly quite for 32ohms)
However I am looking to go to the Sennheiser HD560s.
I could, and I have considered this. I do have my monitors and sub going into a remote controlled switch on my power bar so can use one button to turn them off. But then the headphones would always be running and I thought this wouldn't be ideal to have headphones running for so long.
This is why I was looking at audio interfaces with audio controls for both monitoring as well as separate controls for the speakers. The Focusrite Scarlett 2i2 has separate controls. This issue with these as I doubt they sound as good as they are not dedicated dac's
