Greetings once again to the community
Ok so there is something utterly insane that i 've been trying to solve for a month with no luck at all.
Some games in my pc run just fine (Metro 2033, Little Nightmares, Destiny2), some others crash (Nba 2k21, Horizon Zero Dawn, Control).
The crazy part is that when they crash i go to the GeForce Experience app, reinstall with clean installation the GPU driver and then some of the crashy ones fix, sometimes they just display colored lines through the screen and parts of the image is corrupted and lastly 2k21 just never lets me finish a whole game.
I ve done everything hardware-wise litteraly rebuild the whole system from scratch and removed every single OC related stuff (BIOS, XMP, Auto OC etc)
Last but not least the GPU passes every single stress test i ve put it through FurMark and have configured the fans to go full speed after 55 degrees Celcius via MSI afterburner
System specs
mobo : MSI b450 tomahawk max
CPU : AMD Ryzen 5 3600
GPU : Zotac gtx 1060 amp! 3GB
m.2 SSD : Kingston 2000 (boot drive/windows)
SSD : WD blue
HDD : unknown
Thanks in advance guys...
https://linustechtips.com/topic/1358124-in-desperate-need-for-help/
Just figured out that whenever I download the epic games launcher this problem occurs!!!
If I don't have the epic games installed on my pc everything runs smoothly!
I tried uninstalling and installing it again in both my m.2, SSD and HDD and everytime the games crash...
Could the epic launcher interfere with my GPU drivers???
