Get a 360mm AIO 🙂
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
4 minutes ago, GBodzioG said:
Budget (including currency): 5k £
Country: UK
Games, programs or workloads that it will be used for: Cyberpunk 2077 ect.
Other details : link from partpicker : https://uk.pcpartpicker.com/list/RDRdkX.
Any info or conclusion would be apriciated
I mean all I can do is save you money for no performance loss here that is about it. All your parts are great. Yeah a 360mm aio can be gotten if you so please as Dedayog mentioned.
PCPartPicker Part List
CPU: AMD Ryzen 9 5950X 3.4 GHz 16-Core Processor  (£690.00 @ Currys PC World)
CPU Cooler: ARCTIC Liquid Freezer II 360 A-RGB 48.8 CFM Liquid CPU Cooler  (£111.48 @ Scan.co.uk)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  (£139.93 @ AWD-IT)
Memory: Crucial Ballistix RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£190.79 @ Amazon UK)
Storage: Sabrent Rocket 4.0 1 TB M.2-2280 NVME Solid State Drive  (£150.46 @ Scan.co.uk)
Storage: Mushkin Pilot-E 2 TB M.2-2280 NVME Solid State Drive  (£206.54 @ Amazon UK)
Video Card: Asus GeForce RTX 3090 24 GB STRIX GAMING OC Video Card  (£2157.96 @ Infinite Computing)
Case: Lian Li Lancool II Mesh ATX Mid Tower Case  (£98.99 @ Box Limited)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£93.48 @ Ebuyer)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  (£162.22 @ Newegg UK)
Case Fan: Lian Li UNI FAN AL360 64.5 CFM 120 mm Fans 3-Pack  (£81.99 @ AWD-IT)
Total: £4083.84
Generated by PCPartPicker 2021-07-19 15:48 BST+0100
geometry is hard
b550 > x570
Country: UK
Conclusion you want?  Fantasy build.   it's so overkill for gaming as to be outside the realm of "is this a real request".
You don't need 64GB RAM to play ANYTHING, let alone Cyberpunk.  Or a 16 core CPU.
OnePlus Ecosystem:
3D Printing:
3 minutes ago, GBodzioG said:
Want it to Be a Top Build for next Years thats why i let my self to Overkill it ATM.
Not the best way to do it. You would be better off spending half now and save the other half for future upgrades. Also gpu prices are crazy right now so you will be overpaying.
Is this literally only for gaming? If so, 5950X is not what you want. Not only is far more expensive than a 5900X, but it'll perform worse, as well, unless you're fully utilizing all 32 threads (and you absolutely won't when gaming). The 5900X has better power and thermal headroom, and that can be used to push it past the 5950X in any workload where, again, you don't actually need the 8 additional threads the 5950X provides.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
Chances are even if you shave a ton of specs off that build, you'll have the same experience, pay a ton less and be able to beat it spec wise in just a few years, by a lot, for the same price of your cheaper build today.
Unless you just can go balls to the walls now and budget also won't be a problem later, but even at that, I agree with Chris that the 5950x will not perform as well for gaming as the 5900x does.
It does sort of ring of... "what's the fanciest build I can put together for the sake of it"
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
Total: £4083.84
for a 4000 pound build you use a b550 tomahawk....
I would do something like this. You could make it even cheaper with a different case/cooler and cheaper fans.
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  (£366.90 @ Technextday)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard  (£139.97 @ Amazon UK)
Memory: Kingston HyperX Fury RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£159.99 @ Box Limited)
Storage: Western Digital Blue SN550 2 TB M.2-2280 NVME Solid State Drive  (£179.47 @ Ebuyer)
Video Card: Gigabyte GeForce RTX 3080 Ti 12 GB GAMING OC Video Card  (£1385.70 @ More Computers)
Case: Lian Li PC-O11 Dynamic ATX Full Tower Case  (£126.98 @ Box Limited)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£109.76 @ Infinite Computing)
Case Fan: ARCTIC P12 PWM PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack  (£40.47 @ Scan.co.uk)
Total: £2661.19
Generated by PCPartPicker 2021-07-19 16:38 BST+0100
This 100%. Even the best thing today, won't even compare to something you can get in a few years. We had a period of stagnation for about a decade, but we're very much out of that period now. Things are changing fast and in leaps and bounds.
Dont even bother with liquid cooling if you arent ocing
Just get a b550a apro and a fuma2/mugen5 if you arent ocing, might aswell save some money rather than squandering it on garbage that you wont use anyways or its just overpriced (looking at you expensive ssds, rgb ram, cpu, everything)
https://uk.pcpartpicker.com/list/nM3P4d
This is a very value oriented build or just cheaping out on everything that isnt too important but keeping it decent
You may wish to swap the 5900x and 32gb ram for a 5800x and 16gb ram if its a pure gaming build and you arent planning on streaming
If youd like to oc, swap the board for a b550 tomahawk and the cooler for a liquid freezer 360
And yes i will still keep this disclaimer
corsair rgb pro has good prices in the uk so thats why i choose it for rgb builds and dont bash it for uk folk
Money spent on rgb is around 20-30£ so it will have abit of rgb but rgb isnt a money pit, just something to spruce up the build
