lol idk even no what im talking about i just know swiftech makes this and its called the h320 http://products.ncix.com/detail/swiftech-h320-quiet-power-plug-and-play-24-86340-1294.htm
It's just the name of the product. It uses 3x 120mm fans.
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/135738-water-cooling-question/#findComment-1805284
Do you need some fans for it, do you want another radiator for it, do you want to know how to expand it, or do you just want to know if it's good or not?
yeah are there any other company's that make those complete kits with triple 120's?
There are none that I know of that make 360mm AIO coolers. If you want something similar, you can get kits from companies like EK, but you have to assemble them as you only get the components. Also they are more expensive. Just get the H320.
https://linustechtips.com/topic/135738-water-cooling-question/#findComment-1805296
https://linustechtips.com/topic/135738-water-cooling-question/#findComment-1805307
Do your case support 360mm? And I'd recommend these fans (very quiet): http://www.frozencpu.com/products/10323/fan-674/Scythe_Gentle_Typhoon_120mm_x_25mm_Fan_-_1850_RPM_D1225C12B5AP-15_Hot_Item_.html
Not avaliable on there atm, try to find somewhere else.
Emmh... Maybe consider killing yourself before you talk to me?
Pople on this forum though some of them had a brain, turns out, no.
https://linustechtips.com/topic/135738-water-cooling-question/#findComment-1814027
