Is Intel stock cooler enough to unlock power limits on 10400F
It really depends on what you're planning on doing with the computer. Are you just gaming and watching videos? Then you'll be fine, because that won't max out all the cores. Are you going to be doing rendering on the CPU? Then you'll have a problem.
My current computer came with a Thermaltake UX100, which is kind of like the Intel stock cooler (at the very least, they're both smaller down-draft coolers rated for 65W TDP) and it was able to keep the 9600K (a 6c/6t 95W part) at a reasonable temperature during normal workloads, but when I tried to do Folding@Home on the CPU, that cooling solution folded hard. If I used more than 2 cores in that workload, it would immediately go up to 90C and start throttling.
If you're tight on your budget, you can give the stock cooler a shot and, if it isn't enough, you can upgrade it later. You won't need much for that part. I upgraded to a Vetroo V5 (sort of like a Hyper 212) for $30 and now I stay in the 70C range even when running a 4.8GHz overclock.
