Lazy fire hazard
3 hours ago, Imax said:The basics one should do when getting a new PSU, is to replace all the cables with new ones... but being lazy got me a new idea. Why would I replace a SATA power cable, when the rail fits?
3 hours ago, Imax said:So... why did this happen with the Corsair 1600 and not the previous Seasonic 850 Prime before? Is it just the cable quality/ design? Faulty storage?
It's because you used the wrong cables. The SATA power cable is made up of 12V, 5V, 3.3V, and two ground wires for a total of five pins and one blank in the six pin connector. On the power supply those can be arranged in any order, and different models of power supplies will use different orders. The pinout is different and the cables are not compatible.
https://pc-mods.com/blogs/psu-pinout-repository/seasonic-focus-sgx-cables-pinout
https://pc-mods.com/blogs/psu-pinout-repository/corsair-psu-type-4-cables-pinout
Placing the SATA connections side by side for easier comparison
(Yellow = 12V, Red = 5V, Orange = 3.3V, Black = Ground, White = Not used)
The PSU was outputting 12V where the Seasonic cable was delivering 12V
The PSU had a blank where the Seasonic cable had a ground (blanks might be a ground pin on the PSU anyway with just the connector on the cable empty for that pin)
The PSU was outputting 3.3V where the Seasonic cable had a blank
The PSU had a ground where the Seasonic cable needed 3.3V
The PSU had a 5V where the Seasonic cable needed a ground
The PSU had a ground where the Seasonic cable needed 5V
Never mix cables from different power supplies. This is basically what you did to your computer.
