Budget (including currency): 100 to 600 pounds ( can go 100 pounds higher if needed)
Country: england
Games, programs or workloads that it will be used for: call of duty black ops cold war, overwatch and  minecraft.
Hi I would rlly like to know what to upgrade first out of my pc (sorry about my hard drive and ssd its impossible to find out wht it is)
im upgrading from a
CPU: AMD ryzen 5 3600x
GPU: Readeon 5500xt
motherboard: asus prime b450 plus
cpu cooler: the one that comes with the cpu for free
ram :corsair vengeance 2x8gb
hard drive?: ST1000DM010-2EP102 1tb
ssd?: 512gb pcs PCIe M.2 ssd
https://linustechtips.com/topic/1356668-i-need-help-upgrading/
For those games, nothing.  It's a perfect PC for them.
If it were me, I'd add a 1TB SSD for games and lose the HDD. #AllSSD4Life
GPU's are too expensive to recommend replacing just yet.
3600x is a damn fine gaming CPU.
How are your peripherals?  They impact the experience too.
Why are you wanting to upgrade?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873027
Country: england
im upgrading from a
GPU: Readeon 5500xt
Only thing that would be a major upgrade would be your GPU, but we all know why you can’t get that. I would just save more money for when you actually need to upgrade, as your system sounds fine ATM.
Maybe upgrade the PSU in case your current one sucks?
geometry is hard
b550 > x570
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873029
I agree with all the comments above mine. I would probably add an aftermarket CPU cooler and maybe some better case fans for better thermals/noise levels but it might be unnecessary since all the games you listed are relatively easy to run.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873042
Country: england
im upgrading from a
GPU: Readeon 5500xt
I'm not going to comment on you use case and (edit) I'll offer upgrades for upgrade's sake.
So my advice and observation.
You have a very basic mobo, so can't go Ryzen 9 with a B450.
You RAM speed and timing make a significant difference with Ryzen. Try enabling DOCP if it's not already on and you might see a difference in bench test right away. Otherwise 3600 Mhz Ram with low CAS latency might make a difference Make sure you use only 2 sticks and not 4.
Get a good NVME SSD
    -A 1tb Samsung 980 (PCIE gen 3) would do the trick. Install the OS on it.
    -You might want a second SSD for game loading, that could be a SATA one or you can put in a PCIe expansion card to fit a 2nd one.
Then a good CPU cooler like a Fuma 2 or a Nh d15, assuming you have a well ventilated case. You can keep that for future builds
A 3060ti at MSRP would be a nice step up from you 5500xt. That might happen before Christmas.
A Ryzen 7 5800x would be a little faster while keeping your old Mobo.
Personally, with your budget I would try to flip your current mobo/cpu/RAM for around 300 pounds and get better ones like an x570/Ryzen 7 5800x/ 2 x16 3600 Ram cooler and a gen 4 PCIe SSD. I don't know prices in the UK so you might want to make a budget 1st and make sure your PSU can handle it.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873060
Get a good NVME SSD
I have to respectfully disagree, even though you did preface it.
Your advice would bring his low-midrange machine up to mid-upper level, which is not what I think is appropriate.
A few of the upgrades are upgrades for paper numbers.  NVMe SSD?  Useless for gaming.  5800x?  Useless in those games, except to go from 200fps to 300fps.
3060Ti?  Even at Christmas won't do him a bit of good to blow his whole budget on.
Replacing RAM?  Come on, that's nitpicking and not worth the hassle.  No one I know does that once you have it.
I get that it's spitballing and "if you had $1500" to blow, but it's not reasonable advice in this situation.  I hope the OP doesn't rush out and buy anything.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873086
Thanks i have a razer huntsman mini a 165hz asus moniter a razer kraken x the worst one and a razer orichi
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873121
Guess you like Razer 😉 And hate punctuation 😞
Should be all set for a while. I'd wait until the machine actually doesn't perform at a level you want.  Then look into upgrades.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873128
1 minute ago, M1fflin said:
the reason i wanted to upgrade is i crash alot and i cant download the new cod update for some reason
Would have been good to post in the first place.
What crashing is it doing?  Power off crash?  Blue screen?  Games just close and go to desktop?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873129
thanks yh dont worry i didnt buy anything i could tell some of the stuff he/she/they said would just show in benchmarking and not really do anything in terms of games as most things are in short bursts not long hard benchmarks but i can see why he/she/they might say that as graphicly that might be a improvement
https://linustechtips.com/topic/1356668-i-need-help-upgrading/#findComment-14873185
