I just got a Asus Tuf z590 and 32GP of 3200MHz DDR4 RAM. Unfortunately I can't clock the RAM to 3200 using XMP since I get a memory error and it won't post. The machine seems to work fine when the RAM is at base clock 2133. Could it be bad RAM, or am I doing something wrong?
Thanks in advance for any help!
https://linustechtips.com/topic/1356642-memory-clocking-issue/
Do you have more than 1 stick?
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
https://linustechtips.com/topic/1356642-memory-clocking-issue/#findComment-14872789
Try and work your way up and see what it will boot at?
https://linustechtips.com/topic/1356642-memory-clocking-issue/#findComment-14872795
