Port Forwarding for a minecraft server problems
Go to solution Solved by Donut417,
2 hours ago, MrP6k said:
is there any other solutions to this? or do i just have to get a static ip address?
There is a way using a VPN, though Im not sure how the config works on that. If your ISP offers a public IP address then that would also be a route. Just keep in mind that a Static IP or just a public IP might not be available. The reason Carrier Grade NAT exists is because we have exhausted most of the Internet routable IPv4 addresses. I know in some areas of the world Carrier Grade NAT has become standard. If anything be prepared to pay more. Static IP's tend to cost more money, a VPN will cost money. You might even think about renting a VPS and having them host the Minecraft server for you depending on the costs.
image.png.bb06d22c1643034cf35c1557814ff6ae.pngI'm using a HG8245H5 router, this is what i have set on the router's webpage, but then i used a website to check if the port's open, it shows that it's closed.
the server was running when checking the port.
yes, the server is running on the port 25565
does anyone have any idea what i could've done wrong?
yes, i have added new rules to windows firewall on both inbound and outbound, tcp and udp
Feel free to @ me if you have any questions!
Please press the button if you think my advice was helpful! Thanks!
"Min-Maxing may not always be the best thing to do, but I will always try." - Me, 2021
PC specs:
-i5 2500k
-TP67B+
-Zotac gtx 970 (the wimpy version)
-256gb V-gen nvme ssd (@ me if you want to know how I gave my P67 board NVME support)
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
I've been spamming the "check port" button on the website, sometimes the port's closed, other times it's open. any idea what's wrong here?
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
Have you clicked on the button which says "Add"?
On 4/5/2024 at 10:13 PM, LAwLz said:
I am getting pretty fucking sick and tired of the "watch something else" responses. It's such a cop out answer because you could say that about basically anything, and it doesn't address the actual complaints. People use it as some kind of card they pull when they can't actually respond to the criticism raised but they still feel like they need to defend some company/person. If you don't like this thread then stop reading it. See how stupid it is? It's basically like telling someone "shut the fuck up". It's not a clever responsive, it doesn't address anything said, and it is rude.
MKBHD is but an Apple propagandist and fanboy. Take his videos with a grain of salt, especially about anything Apple. In his video titled "I Visited Apple's Secret iPhone Testing Labs!", he has shown that he makes no effort to fact check Apple's claims, and takes it at face value. I do not believe he can be trusted as an Reviewer/Influencer.
bruh switch to dark mode its at the bottom of this page
VPN Server Guide
that button just adds this
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
Okay, now click on apply and check if it works?
VPN Server Guide
i spammed the check port button, it said "port open" for 3 times, then changed to "port closed"
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
6 minutes ago, fuzz0r said:
Try this site: www.canyouseeme.org
Also you aren't behind a carrier-grade NAT are you? Because if that's the case you will need to talk to your ISP and get a static IP address.
clicked "check port" a few times, got mixed results
what and how do i check for that?
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
If your WAN IP address falls between 100.64.0.0 to 100.27.255.255 or starts with 192.168 or 10 then you're on carrier grade NAT.
2 hours ago, TheEpicDuck said:
What ip are you using in the server properties file?
Its blank
I'm sorry but I don't understand what that means and how i check for it
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
also, i tried hosting the server on my neighbours wifi and it worked flawlessly! we use the same ISP, but they have a
MediaAccess TG389ac High Power router, while i have the HG8245H5
would that have an effect on it?
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
if WAN ip address means public ip address, then no. my public ip starts with a 158.
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
You need to put your local ip in the Server.ip field. Once it's started you can check the ports again
the server failed to bind to the port when i add my public ip
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
hey, i fiddled around the router's webpage and found this, do i have CGN?Untitled.thumb.png.3c9ffccb8332eb20d2c8f125b42fee13.png
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
If your public IP starts with 10 then yes, that would be carrier grade NAT.
PC specs:
-i5 2500k
-TP67B+
-1tb wd blue hdd
-Corsair CX550
-MSI Mag forge 100r
