I recently upgraded my Ryzen 2700x to a Ryzen 5600x but I still have the stock AMD Wraith Prism cooler (the RGB one). I feel like it is good enough for now but I really want to get a cooler that matches my White Aesthetic. I would personally like a AIO but I can't justify spending more than $150 on something that wont affect my performance by that much. I've seen some cheaper AIOs on amazon but not from brands I am comfortable with. Does anyone have any recommendations on a white cooler air or water?
Also I will post Pic once I get home.
https://linustechtips.com/topic/1355864-cooler-help/
If your budget is $150, there are plenty of AIOs that you can get for that price from reputable brands. If you're looking for 360mm, the Lian Li Galahad comes in just below that (see link below) and there are plenty others if you look hard enough. If you're willing to go for 240mm, then you have even more options with most of those being significantly cheaper than their larger counterparts. Air coolers can also be found for pretty cheap as well if you want one of those (Other commenters seem to have already found you a few of those so I won't bother posting another).
https://www.newegg.com/lian-li-liquid-cooling-system/p/2YM-002Y-00002?item=2YM-002Y-00002&nm_mc=knc-googleadwords&cm_mmc=knc-googleadwords-_-liquid %2F water cooling-_-lian li-_-2YM002Y00002&source=region
https://linustechtips.com/topic/1355864-cooler-help/#findComment-14867284
Get an aio for : performance, cpu socket clearence, sff build
Dont get an aio : purely for looks, maximum reliability
If you are ocing that does justify the aio cause large air coolers are very thicc which makes working around the socket a pain in the ass
Otherwise dont bother, the prism is a really good stock cooler already
https://linustechtips.com/topic/1355864-cooler-help/#findComment-14867718
