Budget (including currency): trying to keep it under $3000 usd excluding what I already have
Country: usa
Games, programs or workloads that it will be used for: occasional video editing, occasional 3d rendering, occasional photoshop, Cod, valorant, Forza, star citizen, Minecraft
I Already purchased the power supply and the gpu as a bundle with a few other things from antonline
For the Motherboard im torn between an Asus ROG Crosshair VIII Formula or an Asus PRIME X570-pro
CPU: AMD 5900x
motherboard: Asus ROG Crosshair VIII Formula or Asus PRIME X570-pro (im torn between the two)
memory: g.skill trident z neo 64GM (4 x 16 GB) DDR4-3600 CL14
storage: Samsung 980 pro 2tb m.2
GPU: EVGA GeForce RTX 3080 Ti 12 GB FTW3 ULTRA GAMING (already purchased)
PSU: EVGA G3 750 W 80+ Gold Certified Fully-Modular ATX Power Supply (already purchased)
case: lian li o11 dynamic
cooling: custom loop from ekwb
https://linustechtips.com/topic/1354834-first-build/
Country: usa
CPU: AMD 5900x
If you arent gonna overclock dont bother with custom looping or high end boards with beefy vrms, just a big waste of money you can put to something more useful like a cpu upgrade
I dont reccomend 4x16 nor cl14 cause 4x16 puts alot of load on the imc and may yeild worse oc and cl14 is usually expensive af, cl16 rams can be oced to cl14 anyways so why even bother
If you are only doing occasional vid edits and stuff 980 pro isnt worth it, no noticable speed difference in loading times, only noticable when regularly moving large files like videos, get an sn550 or 980 (non pro)
Seems like a decent build, cant really bash rgb ram cause cl14 sticks are usually rgb anyways
https://linustechtips.com/topic/1354834-first-build/#findComment-14860089
I am planning on overclocking thats why I was torn between going with a higher end board or not.
what would you recommend I go with for ram, 2x32 cl16?
https://linustechtips.com/topic/1354834-first-build/#findComment-14860159
https://pcpartpicker.com/product/3GkgXL/oloy-64-gb-2-x-32-gb-ddr4-3200-memory-md4u323216djda
Rgb ram is way more expensive then that so dont bother
https://linustechtips.com/topic/1354834-first-build/#findComment-14860179
I think youll want a b550e, 14 phase and its not overly expensive
Why b550 over x570?
Only go x570 if you need to use more than 1 gen4 nvme drive, otherwise b550 is superior
https://linustechtips.com/topic/1354834-first-build/#findComment-14860181
