How to connect built in case fans
4 hours ago, jh01 said:Anyone has an idea?
Hello,
Each fan will have two sets of wires: one is for ARGB lighting, the second is to provide the fan power to spin. The connector in the picture you provided with thehad 3 pins and the little wings on each of the the side (JST connector) is for the ARGB lighting. It sounds like you had that wired up correctly, initially. The second set of wires that come from these fans are the DC power wires that have a 3pin connector as well, but the connector should look like the attached picture. The DC fan cable from each of the 4 fans needs to be plugged into the included splitter; wiring of the fans to this splitter might have already been done at the factory. With all the fans plugged into this splitter, you would need to plug the single side of the splitter into a Chas or Sys fan header. I also included a picture of the included splitter below. That should be all that is required to get those fans spinning. I hope this helps.
DeepCool Support
