Problem with fan hub
Go to solution Solved by Alvin853,
The SATA plug is for power, you plug it into a cable coming from your PSU
So I’m trying to connect my Lian Li Uni fan hub and I need to plug in a SATA cord for the fan hub to work, but the gray ones on the side right next to the 24-pin aren’t big enough. Where am I supposed to plug it in? I’m using the Asus Prime X570-Pro motherboard and the Lian Li Uni fan hub that comes with the SL120 fans.image.thumb.jpg.8d70ce53afc9b6caf023848e4dd6d52e.jpg
https://linustechtips.com/topic/1354462-problem-with-fan-hub/
