PSU for 2 VGA`s - what exactly ?
Kent
Hey guys! Im in trouble and I`ve always watched Linus for information, so today I decided to ask for help :).
My problems are:
I have 2 vga`s
EVGA GTX770 SC 2GB and Radeon HD6850 2GB.
1st problem - What PSU do i need to power up both? I`m thinking of an
-XFX ProSeries Core 850W
(ATX 12V V2.31, 80 Plus Bronze, Standard, 2x 6pin PCIe, 2x 6+2pin PCIe, 11x SATA)
or
XFX ProSeries Core Edition 750W PSU
ATX 12V V2.31, 80 Plus Bronze, Standard, 2x 6pin PCIe, 2x 6+2pin PCIe, 8x SATA)
2nd : What exactly do I need , do I need molex or sata, I read about them in various places but kinda didn`t understand them (stupid me)
3rd: Will I bottleneck my system If i keep both cards (although I think its a yes)
I bought the gtx as an upgrade. Also here are my other system specs if needed:
CPU: i7 2600 3.4 GHz
MB: Gigabyte Z68X-UD3H-B3
Mem: 16 Gigs
Integrated Graphics: Intel HDG 1000GT1
Im really looking forward for an anwser. Sorry if I make you guys answer obvious question I just need to make sure im not going to trash my system somehow :). Thank you in advance
Do you want to run both cards simultaneously, or just switching between them?
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems doing CPU installation." -Linus
delid i7-3770k @ 4.2Ghz @ 1.265V | EVGA z77 FTW | GTX 680 2way-SLI | 16GB Corsair Dominator Platinum @ 1866MHz | 240GB SSD RAID 0 | Full Custom Water Loop with two 360mm radiators  -> live temps <-
Both at the same time. Or if its possible to use one for Autocad an the other for gaming :)
the 750w will power them but, personally I would go with the 850w just for extra head room.
The easyest way, known to me, is it doing like this:
-> http://youtu.be/YqkI7bOfRkA?t=4m6s
Just "downscale" it to only 2 Cards, which should not be so different.
If you're doing it like this, than you would only need to power 1 card at a time and wouldn't be worrying about the PSU so much, and the 750w schould be no problem at all.
~ ThxAndBye
Thank you guys. Ill do it in a jiffy
