So I am looking for a NAS to be a media server/backup for baby photos etc. so far this is my top choice. Do you guys have any other ideas.
http://www.amazon.com/Synology-DiskStation-Diskless-Attached-DS214play/dp/B00G9X5N2W/ref=sr_1_1?ie=UTF8&qid=1396578904&sr=8-1&keywords=Ds214play
<p> AMD Ryzen 7 5800x l ASUS TUF X570-PLUS l G.Skill Trident Z Neo Series RGB 32GB l Sapphire Pulse RX 7900 XTX
https://linustechtips.com/topic/135325-nas-solutions/
that looks ok but the WD my cloud looks like a pretty good NAS solution
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/135325-nas-solutions/#findComment-1800323
Looks decent but if you have a spare, unused computer that can hold a couple hard-drives you can install FreeNAS on it and make your own NAS/Media Server so you don't have to buy the enclosure, just the drives.
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
https://linustechtips.com/topic/135325-nas-solutions/#findComment-1800332
For a media server though
yeah if you go to their website you can play videos and look at pictures through the app that you can use on windows, mac, android, and ios
https://linustechtips.com/topic/135325-nas-solutions/#findComment-1800344
The Netgear ReadyNAS 104 is a bit cheaper and has 4 bays so you can upgrade in the future and the software looks pretty good on it. http://www.newegg.com/Product/Product.aspx?Item=N82E16822122135&ignorebbr=1
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/135325-nas-solutions/#findComment-1800345
It's simple, Synology is a reputable solutions provider, and they have some of the best technical support around. Go for it.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/135325-nas-solutions/#findComment-1800775
