Two reservoir water cooling
ReyTech
So I was thinking to water-cooled using two reservoir (don't quote me on that one), So the question is can I use a EKWB distro plate and EKWB pump and reservoir combo unit mounted together in inside the case (Lian-li O11D XL rog certified)
Edit: ok, so there are two custom water loop
*The hardware is just for show off
By two resovoir do you mean redundant pump systems? In case one fails?  Seen that. I don’t know how it would fit with your distro plate though.  I’ve never messed with one of those myself.
You can do it, but it's usefulness is debateable when you're talking about everything in 1 loop.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
go for it, more water to heat up = longer before shit gets hot 😄
