Laptop Choosing Help
Go to solution Solved by mt123,
Seems worth it to me. Though, not really sure how computer hardware pricing/ economics are in Poland (or wherever you live that uses the Polish Zloty).
In essence, if you were buying this in the U.S., I honestly believe this would be pretty reasonable, and if getting 1 TB of storage will come to about ~$1,400, then I think you'll be set.
https://linustechtips.com/topic/1351984-laptop-choosing-help/#findComment-14839327
