So Ive recently took apart my computer and put it back together. Why? I was going to change cases lol.  Anyways the USBs and Graphics card aren't working, but the Cpu fans and case fans are working. Along with the rgb lights. Could there be specific reasons for this?
Edit: the graphics card spins for a bit but still displays nothing.
Specs:
AMD 7  2700x
PSU Corsair 600  80+ gold
EVGA 2060 super
Asus ROG strix B450-F
https://linustechtips.com/topic/1351470-motherboard-issue/
Have you plugged the 6/8pin PCIE power connector back into the gpu? Also which USB's dont work? is it just the fronts? if it is then you need to plug in the front pannel connectors they are cords that come from the front (inside of the case) and need to be plugged into the bottom of the motherboard (not sure of the extact places to plug it all in refer to your motherboard manual).
https://linustechtips.com/topic/1351470-motherboard-issue/#findComment-14834865
Yes, I plugged the 6/8 in and it's all the USB ports, on the motherboard itself as well. I even tried plugging a HDMI into the motherboard without the graphics card and I'm getting nothing.
https://linustechtips.com/topic/1351470-motherboard-issue/#findComment-14834885
This belongs in https://linustechtips.com/forum/5-cpus-motherboards-and-memory/
Triple check your power connectors, make sure auxillary CPU power is connected (4+4 pin at the top of the board)
Make sure the power connectors are properly seated into the PSU and the motherboard connectors
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1351470-motherboard-issue/#findComment-14834889
Further confirming from personal experience with the B450-F what should be obvious to anybody who can look at a pic of one: the CPU power is absolutely not just a 4 pin, it's an 8 pin. And you should be using both halves of a 4+4. Don't know if it would boot a 2700x with only a 4 pin.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1351470-motherboard-issue/#findComment-14834905
Yes so I  did all this and reconnected them again. As for the lights. The only one that comes on for a second or two is the DRAM light.
https://linustechtips.com/topic/1351470-motherboard-issue/#findComment-14834920
Sorry replied to the wrong person but, I did all of this and reconnected them again. As for the lights. The only one that comes on for a second or two is the DRAM light
https://linustechtips.com/topic/1351470-motherboard-issue/#findComment-14834928
