you can just ignore windows, it's probably a warning or something that shows up because of your theme right?, is it an actual error or just some pointless message that pops up that you can remove without any consequences? 8GB should be plenty, could always look in task manager and see how much ram is avaliable and how much you are actually using, see if anything is hogging an excessive ammount of memory, you can probably just ignore windows.
https://linustechtips.com/topic/135098-running-low-on-ram/#findComment-1797072
I would say you're actually running out of RAM. Which is weird, since I only have 2GB (with another 2GB for swap) and I probably push my poor computer farther than most people. And I don't entirely run out (RAM yes, swap no).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/135098-running-low-on-ram/#findComment-1798072
