Hi!
I have a problem with my PC. My computer sometimes freezes and stays frozen. Then the RGB on the keyboard stops working and then I can't even use the computer. I always have to restart it by holding the power button on the case. Sometimes it freezes, my monitors flash and then I hear a sound in my headphones that something has disconnected and then plugged in. I don't know what it might be.
Thank you in advance for your help and answer 🙂
Have a lovely day! 🙂
Specs of my computer:
Processor: AMD FX-6300 Six-Core processor
RAM: 12GB
Graphics card: Nvidia GeForce GTX 1050 Ti
https://linustechtips.com/topic/1350246-problem-with-my-pc/
2 minutes ago, Jakubman625 said:
Hi!
Please add some specs (the more the better) so we know what we are talking about.
Also are you able to see the temps when it does this?
Maybe also update your videocard(GPU) drivers.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1350246-problem-with-my-pc/#findComment-14825369
Hi, yeah i updated the first message. you can see the specs there and yes my GPU Drivers are Up to date! 🙂
https://linustechtips.com/topic/1350246-problem-with-my-pc/#findComment-14825371
On 6/25/2021 at 9:44 PM, Robchil said:
If he found an id 10 t error it would have solved the problem.....
On 6/25/2021 at 7:26 PM, Mr.Cellkill said:
Any errors. Id 10016,  id 2,  id 1500
ok, i tried the following Event IDs and here is what i found:
Event ID 10: Only 1 Information.
Event ID 2: Nothing.
Event ID 1500: Only 1 Information.
Event ID: 10016: A lot of Warnings.
https://linustechtips.com/topic/1350246-problem-with-my-pc/#findComment-14830211
