tempratures Gpu temp issue
Solved by Freakwise,
Just now, ook351 said:im positive at 100% its screw properly but i can re check to be at 1000% sure
While you at it, make sure to check the thermal paste, usually if the mounting pressure is correct the paste would be thin and nicely spread out
