Hey guys. I have recently noticed that after unplugging the power cable from my PC for a couple of minutes (30 as an example), if I just plug it back in and turn ON my PC, then the motherboard shows the VGA light and can take a couple of minutes to boot up. I have an Asus Z490-H. Booting up usually takes less than 10 seconds as the system is installed in a Samsung 970 EVO Plus. The graphics card and everything should be fine as I have never had problems while gaming or anything, so basically it is just the issue with the light on the motherboard and boot time. Is this expected somehow?
https://linustechtips.com/topic/1350126-vga-light-on/
13 hours ago, RTX 3071 said:
Wait so does it happen every time now?
It happens randomly. Mostly after not using the PC for a couple of hours. During the day while using it I can turn it OFF and ON multiple times, and it will never happen, however in the morning it happens on the first boot.
https://linustechtips.com/topic/1350126-vga-light-on/#findComment-14827155
Try resetting your BIOS, maybe that'll help.聽
https://linustechtips.com/topic/1350126-vga-light-on/#findComment-14827471
