So my GPU is a rtx 2080ti. Usually runs about 71C under load...
but it produces a lot of heat and a lot of it gets blown onto the side panel. I didn't think it was an issue but i took off the panel to make adjustments but before I could... the panel crumbled in my hands...
pictures added. .. is this normal?. It was essentially a brand new case i got as well. I don't have any room for intake fans but i do have three exhaust fans. I have a front mounted radiator which acts as an intake but i don't imagine it brings in acool air. (my case could only fit the radiator as a front mount unfortunately). So i'm going to have to buy a replacement panel but .. how do i prevent that from shattering from heat as well?..
https://linustechtips.com/topic/1349984-glass-panel-hot-from-gpu/
you don't
you just got unlucky and got a piece of unstable tempered glass, which happens but quite rarely, unless if the production line has QC issues
-sigh- feeling like I'm being too negative lately
pictures added
Can you provide them in a more standard way? Like this:
Tempered glass can shatter when it is heated non-uniformly.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
This is just a bad price of glass, has nothing to do with the temperature.
The air that comes out of the gpu can't behotter than 71c, and tempered glass will melt at over 1000c, if I understand it right.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
  Hide contents
Yeah!. The glass was definitely heated non-uniformly. The area around the gpu was really hot to touch where as everything else was cool as ice. So the guy im getting a replacement panel from said this can happen due to heat.. ~_~. I mean i guess i could always just not.. get a new panel and do an open airflow thing. But the panel did get super hot to touch around the gpu area.
I don't buy that excuse, phones also use tempered glass and are heated none-uniformly by the SoC.  It was just a bad piece of glass, it happens.  If this was a normal thing to happen to all tempered glass, this forum would be full of people experiencing it.
Just now, Moonzy said:
"super hot" by hand means nothing to a tempered glass, just saying
Surely glass top electric hobs are also tempered glass and heated non-uniformly to much higher temperatures.
i'd like to add that i did grab the panel with my hand and held it from the side (the area where the gpu blows most of the air) and that was also the spot from where it started shattering as i could feel where the breakage occurred first. But i suppose i'll just get a replacement and hope the same thing doesn't happen. thanks
glass have different treatments
glass that is expected to handle hot stuff (like dining table tops) not only go through tempering, they also go through certain heat treatments to stabilize it
tempered glass are unstable crystals that will continue to change, and will shatter eventually
though a lot of the very unstable ones shatter right as they exit the tempering machine, but there are cases where they shatter few years later, albeit quite rare
i worked with glass machinery for a bit, so i learned about this roughly from colleagues
