My current main desk has a 24” 1080p 1ms 144Hz TN from Acer along with two 1080p 24” 5ms 75Hz IPS from Asus.
I also have an extra 32” 1440p “1ms” (G2G) VA from AOC that was more of an impulse buy that I don’t use much at all anymore.
I’m planning to build a new setup altogether and was wondering if I could get some recommendations for both 1440p 27” and 4K 27” monitors (that don’t completely break the bank for a multi monitor setup) and are somewhat bezel-less with one being high refresh rate as a main / gaming.
The reason I ask for high res is just for ultra sharp text and at least from my experience I can tell the difference between 1440p and 4K. The reason for the 27” in specific is because I did 32” for 1440p and I wasn’t super happy with that decision. I wanna do 27” because it feels like a nice in between 24” and 32”.
I don’t plan to do professional video or graphics work but if there are any deals or just seriously bang for the buck displays with high color accuracy that’d be cool too.
All I really know of is some Dell and LG displays and would love some help finding some probably better options.
https://linustechtips.com/topic/1349488-i-need-help-choosing-monitors/
LG 27GL83A-B for 1440p 144hz.
I have only good things to say about mine after using it for a year. Currently $285 for Prime Day. https://www.amazon.com/LG-27GL83A-B-Ultragear-Compatible-Monitor/dp/B07YGZL8XF/
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
That's actually a really good deal. Normally i'd go for something higher end, but if OP doesn't need wide gamut support, then this is pretty much unbeatable in terms of value.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
