Rx 570 4GB Frame drops
Cunk
(Specs at the bottom)
I have an MSI RX 570 4GB Gaming X.
I recently upgraded my SATA SSD to an NVME drive
I cloned my SSD to my NVME and stopped using the SSD
Every since I have been experiencing severe frame drops to the point every game is unplayable
When I'm in a game my GPU clock spikes to 1281mhz (not overclocked)
When the fps drop happens the clock drops to 300mhz
When the game comes back then it clocks back to 1281
I know these games worked on my setup as I've been playing for over a month with no issues
I swapped back to the SSD but the problem is still there
I rolled back the GPU drivers to a previous version that worked (21.5.1) and the issue is still there
Games are saved to a 2TB hard drive but I've uninstalled them and reinstalled them to the NVME and still having problems
I undid every single change I did to the computer before the issue started and it still doesn't work
any tips?
Video Showing Problem:
https://youtu.be/2zxLvG8t1Pk
The Video isn't a choppy recording that's just how games play
Only way DBD doesn't frame drop is if I play 1080p low settings at 65% resolution scale
Specs
Games: Dead by Daylight, Beamng.Drive, Phasmophobia, etc. (Every game I've tried but those are the ones I play most)
CPU: i5-10400
Cooler: Hyper 212 BE
MOBO: MSI B460M PRO-VDH WiFi
RAM: Crucial Ballistix 3200mhz DDR4 (Clocked at 2666mhz because CPU doesn't support faster)
GPU: MSI RX570 4GB Gaming X
PSU: 500w
NVME: Western Digital Black 500GB (WD Black SN750
SSD: PNY 500GB (PNY CS900)
HDD: Seagate Baracuda 2TB
