Hey guys
I have a custom loop and i would like to change the colour of the water. i want to change the colour to white. what is the best brand of dye to choose i herd mayhem is good.
You can get Mayhems Pastel Ice White dye and add it to distilled water. If you don't want to mix stuff, you can get Ice Dragon White coolant (I think that's what it's called.)
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/134903-water-cooling-dyes/#findComment-1794349
