Hey guys, just attempted to add 16gb of ram with the speed 3200mhz to my pc and after installation, my pc began to shut down automatically all of suddenly? And couldn't figure out why? I’ve tried tweaking around in bios, adding the XMP profile, made sure it would giving out enough voltage to the ram and still kept shutting off. Then, when I just inserted one stick of ram, it seems to work just fine but when I add the second one, it runs fine for like 5-10minutes and then it shuts off again. Has anyone else had this issue? Could it be the PSU ?
https://linustechtips.com/topic/1348889-adding-3200mhz/
What are your system specs? Particularly, board, CPU, RAM (make and model), PSU.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1348889-adding-3200mhz/#findComment-14814952
Is that just one stick of Ram? it would be better to get dual channel, so 2x8GB
10 hours ago, Nicholas Rodriguez said:
PSU High power 80 plus bronze 500-watt
Is that the brand? you should always try to get a good psu instead of cheap / no name brands, a psu is always the most important part of a PC.
Look here for example
-Scott Manley, 2021
https://linustechtips.com/topic/1348889-adding-3200mhz/#findComment-14815797
Yeah, I’m sorry, the two ram sticks are actually a (8x2gb) already ? I just got a new PSU EVGA supernova coming in tomorrow so I’m hoping just adding the two sticks of ram, won’t turn off still while gaming. If it does, then it’s probably the sticks causing the issue
https://linustechtips.com/topic/1348889-adding-3200mhz/#findComment-14815966
