MBR to GPT issue
Solved by Helpful Tech Witch,
Just now, OCNewbee said:Yeah thanx but doesnt work. Already tried it. I think it said something about pagefile.
Could you try it again and report the error?
It might be that you will need to disable the pagefile to do it.
Or create a installation media and use it's CMD to do it from there, as it won't be the booted system partition, it might work.
Featured Topics
WildOne ·
solarbear ·
Posted in Troubleshooting0 -
4
2
2
tjrose91 ·
Posted in Servers, NAS, and Home Lab4 -
Ryoku ·
Posted in Power Supplies3 -
yamilsteven ·
Posted in Power Supplies2 -
arCheese ·
Posted in CPUs, Motherboards, and Memory6
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
