Need Urgent help
Go to solution Solved by BigDamn,
4 minutes ago, SagarBajpai said:
Unfortunately, my motherboard doesn't have a HDMI Port. It has a VGA and a DVI port, and my monitor only has a hdmi port connected to my gpu's hdmi port.
Unplug your system and remove the CMOS battery for around 60 seconds. Re-insert the battery and try to boot the system again
Hey guys,
So, i bought a new set of adata xpg gammix d30 8gb ddr4 ram 3200 mhz, to replace my old 2400mhz ram sets.
After, installing the new ram sets, i am not getting a display. My motherboard, MSI A320 PRO VD/s, has an ez debug portion where the light is stuck on boot with no display.
The light goes momentarily from cpu led, to dram, vga, and then gets stuck at boot.  I had also ordered a new ssd to replace my hdd.
Also, Now my old ram doesn't work either. It gets stuck at boot led.
Tried all basic methods
1. Tried with one stick of ram, and then to both the sticks,
2. Removing and re-seating the cmos battery,
3. Ensured all the wires are connected,
4. Tried with hdd, ssd once at a time,
5. Ensured proper force to install ram.
What could be the possible reason behind this that even my old ram doesn't work. I didn't damaged the motherboard ram slots while installing the new ones.
Ryzen 3 2200g,
A320m pro vds msi,
Cm 550w mwe 80 plus,
Rx 570.
https://linustechtips.com/topic/1348224-need-urgent-help/
I presume the system boots normally if you put the old 2400mhz RAM back in?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809693
Splash screen doesnt show up so you cant enter the BIOS? Boot error is one of the few that doesnt affect going into the BIOS.
Desktop benching:
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809700
Sounds to me like it may be booting just fine. Have you tried switching to the display output on your motherboard? It may be set to integrated graphics.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809750
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809791
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809802
55 minutes ago, SagarBajpai said:
I get no display. Its just a plain black screen.
that means something like ultra fast boot is enabled (so it skips the splash screen and directly tries to boot the OS). Need to clear CMOS to get rid of the setting then
Desktop benching:
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809821
Sometimes if I push my system too hard, example:
1900 1:1 13-13-13-32 2T 1.645v = hard lock.
Clear cmos, pulling battery, nothing like that works. Dead board. Hangs at orange light.
Install my GTX 580 that is about 2 days older than dirt hit go and it fires right up.
I don't really have anything else to offer.. other than it is definitely memory related 😄
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14809953
Thank You so much. I did that, and it worked. No idea why it didn't worked the first time, but anyways thanks a lot. I really appreciate it.
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14812399
Thank You so much for the help. I really appreciate it. 🙂
https://linustechtips.com/topic/1348224-need-urgent-help/#findComment-14812404
