Onkyo TX-NR616 | Sub out issue
Solved by circeseye,
10 hours ago, abass44 said:@circeseyejust tried the rca to 3.5mm and connectedtnrough my phone. It had audio come through, but it was fairly soft and was really clear. Is it mean to come through clear? When I say not clear it sounded kind of distorted.
if you had to crank the volume low sides out
soft and distorted yea low side is done
if low side was working it would be loud and clear with very little volume
