Plizzzz help me regarding my boot drive
Hyz
Guys can u all help me, I have this problem when I start my pc it give me the error on the pic,  only after several restart it works,  I've changed my sata cable but still not working, it's a crucial b 500 SSD 120gb, and my motherboard is Asus P5g41t-m lx3 and for some reason I can only use the first Sata port, in event viewer it's says one error regarding atapi, if u can help plizzzz help, already reinstalled windows, also windows keeps freezing randomly, i cant even play valorant anymore and getting a new pc is far from possible so help me if u can
Looks like silicon death has occurred.
That or you MB has gone bad.
If possible:
Try the drive in something else
Try use bootable USB to boot PC and test drive, like Puppy Linux or Windows Boot Drive(can get from Microsoft Site)
Update the BIOS on MB
If you have you have anything important on the drive back it up immediately then continue with troubleshooting!
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    MSI Optix MAG342CQR 34" UWQHD
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
something like this happened with me last year with my hdd had to replace it now its happening with my ssd
