Since yesterday my PC has been acting odd
- a few days ago the monitor lost signal but it looked like the PC was still on.
- yesterday it restarted when playing CS GO
- This morning it restarted when playing CS:GO
- then shortly after when I was "working" I use Citrix to log onto my work PC and had CS GO on the background - the display went off, and the PC was still on as I could log onto my PC via Google remote desktop.
specs
AMD R5 5600x
32gb 3200 Crucial ballistix
Asus Strix B550i
Nvidia 3070 FE
Case - NZXT H1(with all riser fixes)
PSU NZXT 650w gold
My 3070 is at power limited to 80% and temps don't go over 78c
latest drivers...
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/
specs
AMD R5 5600x
Asus Strix B550i
Nvidia 3070 FE
PSU NZXT 650w gold
My 3070 is at 80% and temps don't go over 78c
latest drivers...
your gpu is at 80% without doing anything or when playing?
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14804408
sorry meant power limited to 80% - I have a SFF PC to reduce temps
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14804423
so ive just done a 3D mark stress test
20 loops of timespy and it passed?
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14804468
2 minutes ago, ThisNameHasBeenTaken said:
What brand are you using?
Have you contacted the manufacturer yet?
it's the founders edition
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14804647
37 minutes ago, ThisNameHasBeenTaken said:
So you've set the power to 80%, what about the clocks and voltage? Did you tune those down as well?
ive set the power limit on afterburner to 80%, it automatically clocks the card and voltage. also ive had this for months
did another 3dmark stress test and it crashed at the end
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14804749
Voltage regulation modules getting hot?
Ryzen 9 5900x CPU
Asus Dual 3070 + EVGA FTW3 Ultra 3070 GPU(S)
Asus ROG Strix B550-F Motherboard
Corsair Dominator 16x2 3600mhz RAM
Corsair H100x AIO
Rosewill S500 Case
Thermaltake RIING 12 fans (4)
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14804996
not sure as cant get that info on hwinfo
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14805342
erm im stupid.....
the GPU power was loose on the PSU side
tried my sons 3060TI FE
changed riser cable lol
then realised the GPU power was loose on the PSU side
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1347587-odd-gpu-behaviour/#findComment-14807078
