I've some problem with my PC. I built one last week and now my gpu temp max is 60 C , but MSI Afterburner said its 85 C, and after testing a few games, my fps is lower than my 1060 laptop. I watched reviews on the internet and from what i seen my FPS is too low from the expected fps, so i tried to tweak it. The gpu i have is actually used one.
I tested furmark only and the temp wont go up above 61 C. Anyone knows what cause my low fps ? is it because of the limited temperature ? or could it be something else ?
I've tried reinstalling MSI Afterburner, Driver for GPU, Updating GPU, and its still the same. Please help
My Specs :
CPU : Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
GPU : ASRock Radeon RX 570 4GB
Motherboard : ASRock B460M-Pro4
PSU : Armaggeddon Voltron Gold 600 80Plus Gold
RAM : Lexar 2x8 GB 3200MHz
Storage : 1TB HDD and 256 M.2 Nvme SSD
https://linustechtips.com/topic/1346662-gpu-problems-or-maybe/
then where did that 60C number pop up?
Desktop benching:
https://linustechtips.com/topic/1346662-gpu-problems-or-maybe/#findComment-14797849
My Specs :
Some of the parts in that list sound a bit on the suspect side, to say the least... can you get the system to boot without the RX570 installed?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1346662-gpu-problems-or-maybe/#findComment-14797942
