You must also enable "Above 4G Decoding" in BIOS for RBAR to work.
NVM, turns out me no read good
Main Rig:-
Server:-
https://linustechtips.com/topic/1346538-resizable-bar-help/#findComment-14796933
There are a list of requirements you need to enable rebar.
Have you updated to the latest vbios?
https://www.nvidia.com/en-us/geforce/news/geforce-rtx-30-series-resizable-bar-support/
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
https://linustechtips.com/topic/1346538-resizable-bar-help/#findComment-14796934
yes. i updated the vbios like 20 min ago and still says no
https://linustechtips.com/topic/1346538-resizable-bar-help/#findComment-14796939
If you've done everything on the list, then the system may need a reboot after all the updates.
https://linustechtips.com/topic/1346538-resizable-bar-help/#findComment-14796947
8 minutes ago, Icjit said:
damn thanks.
No problem.
You're not missing much tbh.
Perhaps a 5-7% gain on a few different titles.
However, some titles actually have worse performance with rebar enabled.
https://linustechtips.com/topic/1346538-resizable-bar-help/#findComment-14796996
