Hello guys i have a really bad computer that barely runs gta 5 on medium setting and i want to upgrade BIG like to a 3060 ti BUT i dont trust myself in building a computer and while the gpu prices are really high im looking to buy a prebuilt i have found one that i want and i would be really happy if some of you guys could look though it here is the link>https://www.power.se/datorer/datorer/stationar-dator/medion-erazer-engineer-p10-i5-stationar-dator/p-1174048/ i think its pretty good
https://linustechtips.com/topic/1346230-help-me/
The pics don't show you much, the airflow looks pretty bad and they make no mention of what actual parts are used for the power supply and motherboard which can have a huge effect on the longevity of the system.
If you can, contact them and find out the *specific* model of the motherboard, power supply and see if you can get some better pics
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1346230-help-me/#findComment-14794852
You should really save up a bit more and get something like this:
https://www.power.se/datorer/datorer/stationar-dator/hp-omen-25l-gt11-1426no-stationar-dator/p-1164775/
The CPU upgrade is well worth it and you can fit all of those components in a better case later on down the line if you want.
My guess is that you will wanna fix the thermal solution too - airflow in 99% of prebuilt cases is shit, get a new CPU heatsink and a couple of fans - maybe "mod" the case with a dremmel and open a nice airway at the front LOL.
Heres a nice summary: https://www.reviewed.com/laptops/content/hp-omen-25l-2021-review
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/1346230-help-me/#findComment-14794859
From what I've heard Omen's are one of the better airflow cases when it comes to prebuilts (not like there is strong competition) and with a 65W TDP cpu, they should be fine, probably worth upgrading if they get a higher TDP cpu though.
https://linustechtips.com/topic/1346230-help-me/#findComment-14794898
I asked for more info and they sent back a list.
Design x31 Erazer
Brand MEDION
CPU Intel Core i5 - 10400F
Motherboard B460H4-EM
Sound 6-channel-Audio on board
Memory ddr4 ram 16384 MB 3200 Mhz 2x8
Graphic nVidia Geforce RTX3060TI - 8gb Gddr6
HDD2 512 gb m.2 PCIe SSD
Operating Software Windows 10 home
Power 650W 80 plus bronze
https://linustechtips.com/topic/1346230-help-me/#findComment-14796771
21 hours ago, Downkey said:
The airflow looks horrendous and many parts aren’t specified. Avoid this.
Design x31 Erazer
Brand MEDION
https://linustechtips.com/topic/1346230-help-me/#findComment-14796772
Design x31 Erazer
Brand MEDION
https://linustechtips.com/topic/1346230-help-me/#findComment-14796773
Can't find that mobo online, probaby a re-brand of something OEM.
They still aren't telling you anything. That power supply is just begging for trouble, I'd skip this
https://linustechtips.com/topic/1346230-help-me/#findComment-14796775
do you think this is better https://www.power.se/datorer/datorer/stationar-dator/hp-omen-25l-gt11-1426no-stationar-dator/p-1164775/
https://linustechtips.com/topic/1346230-help-me/#findComment-14796778
Professional opinion:
I wouldn't buy an HP product if you gave me the money to buy it with. They use bottom-of-the-barrel parts, barely designed to hold together past their warranty date, technical support is the worst I've ever seen.
Skip!
Here, let me help you a bit in your search:
Unless the manufacturer specifically lists which model mobo/PSU/GPU and case they use, pass on them. It's really important to know this stuff.
https://linustechtips.com/topic/1346230-help-me/#findComment-14796799
Skip!
They're OEMs, they're not gonna list that and the chances of getting something else is slim. At this moment there are 2 options, settle for a OEM system with the tradeoff of having bottom-barrel components, or pay 3x MSRP for a GPU. So yeah, IMO the HP system has flaws, but they're fixable and he's got a decent system that will definitely work.
Fixes:
CPU cooling.
Add fans
Clean install windows (to remove HP crapware and all that shit). You can even use the OEM license it comes with.
https://linustechtips.com/topic/1346230-help-me/#findComment-14796830
16 minutes ago, Tatrik said:
can you recommend a prebuild?
Well.....hmmmm.
Personally, I use workstation-class systems (Dell Precisions) but I a not a gamer, so raw gaming performance isn't the standard I'd go for.
THe first system you posted you could buy, but I'd replace that PSU immediately with something of much better quality, and I"d look over the cooling in terms of both airflow through the case (and make modifications as needed) and especially the VRMs on the mobo.
https://linustechtips.com/topic/1346230-help-me/#findComment-14797050
Fixes:
CPU cooling.
Add fans
do you think this is good? https://www.power.se/datorer/datorer/stationar-dator/lenovo-legion-t5-r5-26amr5-stationar-dator/p-1164247/
https://linustechtips.com/topic/1346230-help-me/#findComment-14798744
19 hours ago, Radium_Angel said:
Well.....hmmmm.
do you think this is good then? https://www.power.se/datorer/datorer/stationar-dator/lenovo-legion-t5-r5-26amr5-stationar-dator/p-1164247/
https://linustechtips.com/topic/1346230-help-me/#findComment-14798745
Well, please bear in mind pre-builts, whether from HP, or Dell or Lenovo, are going to have issues in the upgrade path down the road, especially in the case of the Lenovo when it comes to a faster CPU, so if you are okay having a system that you may or may not be able to change much down the road, then that system is fine.
https://linustechtips.com/topic/1346230-help-me/#findComment-14799037
im prob gonna buy this one https://www.power.se/datorer/datorer/stationar-dator/hp-omen-25l-gt11-1414no-stationar-dator/p-1164774/ because it seems easy to upgrade. I mean there is a guy adding fans and removing everything from the old case and adding it to a new case. The only thing he didnt take out was the cpu.
https://linustechtips.com/topic/1346230-help-me/#findComment-14803238
