I live in Australia and thinking of getting this setup. I am just checking if anyone can see if there is a problem with any of these choices. I know there is no Gpu and will probably will wait till I can get a Good one like a 3060 for a reasonable price. Thanks in advance
CPU: AMD Ryzen 5 3600XT 3.8 GHz 6-Core Processor  ($329.00 @ Mwave Australia)
CPU Cooler: Corsair H100i RGB PLATINUM SE 63 CFM Liquid CPU Cooler  ($199.00 @ Mwave Australia)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($129.00 @ PCCaseGear)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($159.00 @ Austin Computers)
Storage: Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive  ($122.00 @ PC Byte)
Case: Cooler Master MasterBox TD500 Mesh White w/ Controller ATX Mid Tower Case  ($119.00 @ Mwave Australia)
Power Supply: Corsair RMx White (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($200.00 @ Amazon Australia)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($148.00 @ Mwave Australia)
Total: $1405.00 AUD
https://linustechtips.com/topic/1345576-my-first-pc-build/
No point in building a PC until you can use it.
I wouldn't get a PC without an SSD, and I wouldn't get a CPU that old for that amount.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1345576-my-first-pc-build/#findComment-14789644
3 minutes ago, Jaizach said:
What cpu would you recommend
Any reason you went with the Corsair AIO? You could shave money off there and go for a 5600x.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1345576-my-first-pc-build/#findComment-14789652
Total: $1405.00 AUD
get an SSD like @dizmo says, get a 5600x by using some AIO funds like @IkeaGnome mentioned, and you will need a video card otherwise the system will essentially not work because you will have no video signal. either get a processor with integrated graphics or get a dedicated card.
EDIT- oops saw u wanted a 3060. just know that you cannot use the system till you get the card.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
https://linustechtips.com/topic/1345576-my-first-pc-build/#findComment-14789654
PCPartPicker Part List
CPU: Intel Core i5-11600K 3.9 GHz 6-Core Processor  ($339.00 @ Skycomp Technology)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler  ($75.00 @ Amazon Australia)
Motherboard: Gigabyte Z590 GAMING X ATX LGA1200 Motherboard  ($239.00 @ JW Computers)
Memory: G.Skill Trident Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($115.00 @ Austin Computers)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($123.78 @ JW Computers)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($125.00 @ PCCaseGear)
Power Supply: Enermax Revolution D.F. 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.00 @ Mwave Australia)
Total: $1115.78
Generated by PCPartPicker 2021-06-08 09:07 AEST+1000
Use the integrated GPU until you get a GPU for a good price and I'd recommend using windows 10 unactivated
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1345576-my-first-pc-build/#findComment-14789670
7 minutes ago, Jaizach said:
Would a Samsung 860 EVO 1tb SSD work with my motherboard which is a ASRock B550M Pro4 Micro ATX AM4 Motherboard
If you wanted to build now, @davemchas a good list with integrated graphics. If you're holding off for the GPU, here is a 5600x. Cheaper cooler and ram makes room for a 1 tb m.2. I went for a faster but smaller HDD for the same price. These are cheap and can be added on later as you need more storage. It's actually enough cheaper than your original list that you could add a second one of the 2tb HDD and have the same storage at a slightly cheaper price overall. You can also get Windows much cheaper.
https://au.pcpartpicker.com/list/MTxngt
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1345576-my-first-pc-build/#findComment-14789685
