General Driver issues/ uninstall help vJoy
Go to solution Solved by ndesign.ie,
go to Device Manager in old Control Panel and remove it from there, you may want to check the remove driver
I NEED HELP QUICK,
i have my PC with my Radeon HD 6790 and i have the shady vJoy driver and i want to uninstall it, but when i want to uninstall it via the uninstall menu from windows 10 or the uninstall .exe packed with the software it just says "File Corrupted" i read that i can uninstall it via the Windows 10 Safe Mode, but now the catch, when i boot into safe mode my Graphics card driver obviously doesn´t get loaded but the unfortunate thing is without the driver my two monitors can´t reconise the signal coming from my Graphics Card, so is there any way i can remove the driver or boot in Safe Mode with loaded Graphics driver?
https://linustechtips.com/topic/1344989-general-driver-issues-uninstall-help-vjoy/
