http://pcpartpicker.com/p/3klzZ
so this is my first build, and i was hoping for some input to weather or not the 2011 socet is worth the money?
i could go to the i7 4770k and save money on my mobo but from what i read the 4820k is better for 3d modeling and rendering.
im greatful for any help on this situation
https://linustechtips.com/topic/134463-cpumobo-help/
1. You did not use a motherboard that is listed on pcpartpicker.com so it did not add the price. 2. What is your budget? 3. What are you going to using the pc for? 4. No it's not worth it. 5. Welcome to the forums enjoy your stay 6.Total overkill on the ram. 16 should be enough and evewn if you need 32 you can get much cheaper ram.
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788655
Totally depends on what you're using the system for--are you working in the field? Just learning? Fooling around?
Programs being used? Type of renderers and settings? Average poly count?
How much money do you have to blow?
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788671
wow so many replies so fast. i am a engineering student just learning to toy around with computers my budget is 1,600$ and i will be using this for 3d modeling video editing/rendering light programming. as far as my mobo goes it is listed on newegg (open box) at 247$ http://www.newegg.com/Product/Product.aspx?Item=N82E16813131800R the ram i got from a friend at a discounted price yes its 32Gb and 2133 but i didn't spend 350 on it. hope that answers most the questions
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788734
The 3D and programming work you'll do as an engineering student will easily run on a modern celeron. Don't waste your money.
I doubt you'd need any more than the standard 8GB ram..
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788754
im sorry im unaware of what celeron is.
It's one of the low end lineups of inte's cpus.
For example: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116974
and for perspective: i7 > i5 > i3 > Pentium > Celeron
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788825
So your saying i don't need any more then a Celeron for the programs i will be using, but are you really suggesting i buy one? i will be doing some gaming on this computer too
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788858
I'm not suggesting to buy one. I'm just bringing into perspective how a 4770k or going 2011 would be overkill.
As for what I would recommend, it would depend on your budget and whatnot. read the link in my sig: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1788871
ok lets see if i can get all the needed information in one neat poast
http://pcpartpicker.com/p/3kotE overall build not counting case and ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131800R  price of mobo i am looking at
budget is 1600$ USD.
aim is for 3d modeling video editing and gaming. mostly a work station tho
i will be running two 1080p monitors
i am upgrading from a 6 year old laptop that take 3 minutes to render one minute of video :P
mostly i am hoping to find out if i can get the same performance and upgrade capacity with less money.
https://linustechtips.com/topic/134463-cpumobo-help/#findComment-1789006
