need to backup tubo tax and quicken but how?
Solved by RML Futuristics,
Hi Elite
Personally with this one i would say a good bet is to jump into the program files, if you root around you may find a documents folder/files folder in there which you can copy which will help, if im honest, im not familier with these programs so i am taking nothing more than a guess, but this should be a step the right way.
Here is a link to turbo tax and quicken after some googling, i hope this helps
https://ttlc.intuit.com/questions/1901360-save-a-backup-copy-of-your-tax-file
Yours,
Sir DrowHunter
