Dust Proof Case.
1 minute ago, Zombie69ner said:The only one I could find in where I live is the Fractal Design FD-C-MES2X-02 Meshify 2 XL and it is a E-ATX which I don't know really what it means.
It is in my price range, and it has dust protectors on every vent. I might pick this one up. What is your thoughts on it?
EATX basically means extra ATX. its a slightly bigger motherboard than the ATX board so if it supports an EATX it will more than likely support the mATX you have now and the ATX you were looking at.
i can not give you a definate yes or no as i do now know. i went from a mod tower to a super tower like it said but it seems like a good over all case. before you buy it i would get the messurements of your GPU because its going to have to fit inside the case with the cables attached and side panel closed to make sure you get limited dust inside the case.
