Budget (including currency): $2,500 - $3,000
Country: United States
Games, programs or workloads that it will be used for: Upcoming games like Dying Light 2 and school work.
This is going to be a whole new build and this is what I have atm. Any idea to help me still make this good and cheap would be a great help.769485217_download(2).thumb.png.24fd5e02c88ec4f8784690ee560cdbe1.png
https://linustechtips.com/topic/1343253-new-pc-build-and-need-help/
Ok so this is just a awful value system. 600$ for what is a low mid range card is crazy let alone the other prices.
I would simply get a prebuilt as the core specs of this system can be found in good 800-900$ prebuilts. Then just add a bigger ssd. But don't waste your money on a 980 pro. It will NOT AT ALL be faster in the tasks you have described compared to a cheap mx500 2tb ssd. Like at all.
https://www.bestbuy.com/site/hp-omen-gaming-desktop-amd-ryzen-7-5800x-16gb-memory-nvidia-geforce-rtx-3060-ti-1tb-ssd-jet-black/6454567.p?skuId=6454567
This thing exists and STOMPS on your current system here.
Now for the build:
Overpaying for the motherboard. Plenty cheaper boards that are just as good if not better
Beyond overkill cooling and a waste of money
No need for 32gb of ram for gaming
Ssd already said that
Gpu is such a bad value so I advise a prebuilt
No need for windows retail. Go on ebay and get a 3$ key.
https://pcpartpicker.com/list/zG9FNP this one should do what you need but you still need a gpu and for an os you can get one from ebay for max 20$
Yeah you made a good sensible build that is not worse in any way compared to ops. The only issue is gpu and that is basically unobtainium now. Hence my recommendation for the actually fairly decently made hp prebuilt (and for a prebuilt that is saying A LOT compared to the dumpsterfire that others are).
Now for the build:
Will this PC still be good for streaming because I wanted to get into stream as well?
I'd strongly advise not going for that prebuilt.
Some of the changes I'd make to your original list are:
Motherboard: Gigabyte B550 Aorus Elite | Simply put, it costs less and will do everything that the other board can that you'll actually use. -$70
CPU Cooler: Cooler Master Hyper 212 | While you could argue that overkill cooling isn't a bad thing, you're going to want the budget headroom. -$150
PSU: EVGA Supernova 550 GA | Your CPU is rated at 65W, so you can throw some pretty hungry cards in with it and still be safe. -$60
An RTX 3060, 3060 Ti, 3070, or RX 6700 XT will be your most optimal choices for this system. If you're reasonably near a Micro Center, you should be able to find one of these at a price that doesn't make you gag.
the pc guy
PCPartPicker Part List
CPU: Intel Core i7-10700 2.9 GHz 8-Core Processor  ($284.99 @ Walmart)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  ($29.99 @ Newegg)
Motherboard: MSI MAG B560M BAZOOKA Micro ATX LGA1200 Motherboard  ($142.98 @ Newegg)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL19 Memory  ($74.97 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($119.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($55.49 @ Amazon)
Case: Cooler Master MasterBox NR400 (w/ODD) MicroATX Mid Tower Case  ($59.99 @ Amazon)
Power Supply: Enermax Revolution D.F. 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Newegg)
Case Fan: Corsair AF140L 67.43 CFM 140 mm Fan  ($4.99 @ Corsair)
Total: $893.37
Generated by PCPartPicker 2021-05-31 18:42 EDT-0400
Use the iGPU on the 10700 and wait for stock on an RTX 3080/RX 6800XT.
Why? It is one of the few prebuilts that aren't crap. It also just straight up has FAR better specs for a LOWER price than ops build.
