My computer wont boot and its been two full weeks of troubleshooting and I am on the verge of giving up,
Specs:
r5 1600
msi x570 gaming edge wifi
xfx radeon rx 570
vengeance 2x16 ram
750 coolermaster psu
The computer wont boot, everything lights up as if it is on but no video signal.
Ive called everybody and they got nothing.
https://linustechtips.com/topic/1343034-help-me-my-computer-wont-boot/
Have you re seated the GPU?
tried different cables for the GPU to the display?
Tried a different port on GPU/display?
Made sure you are running the latest bios?
Tried the RAM sticks in different slots?
Made sure the PSU switch is in the correct position? (I did that once)
Did you update the BIOS? 1600 isn't officially supported on x570 chipset. The BIOS that supports the 1600 was only released in November and not with the release of the board, so it might not be supported out of the box.
https://www.msi.com/Motherboard/support/MPG-X570-GAMING-EDGE-WIFI#support-cpu
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Specs:
r5 1600
xfx radeon rx 570
vengeance 2x16 ram
Like @IkeaGnome said maybe it was cpu problem, since it's kinda not supported by the bios on that motherboard
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
