I need help
Go to solution Solved by TRNoob,
i have a motherboard that is dh61bf and a rx550 graphics card (my processor is i5 2nd gen) when i tried installing the driver for the rx550 and restart my pc
i had a problem that is restart looping my pc
sometimes it bluescreen and my pc never opens while in the boot up part
https://linustechtips.com/topic/1342813-i-need-help/
That was quick...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1342813-i-need-help/#findComment-14768580
